Car Blows Blue Smoke, Cant Pass Emissions.
Old Mar 30, 2012 | 12:42 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
back again with my second question, you guys helped me figure out the part in my first question and i fixed that part. but now I have another question, i apologize if this was already asked a million times, but what can make your car blow out blue tinted smoke when you first crank it up? i know its oil being burned but what can you do to fix this? i took it to a shop and they said they dont wanna try and fix it because i would need a new motor, i know there has to be other options for this fix. but until i fix it i cant pass emissions and my tags are already expired. the car only blows out the smoke like 1 out of every 8 times i start it up. and the shop said they had the rpms up and it was puffing smoke like a cheminy. i will test that later myself... any suggestions on how to fix this? any and all help would be appreciated.
my car is a 1992 chevy cam, with the 5.0 TBI engine.
Old Mar 30, 2012 | 12:48 PM
ex-x-fire's Avatar
Re: Car Blows Blue Smoke, Cant Pass Emissions.
Valve guide seals are a known problem on sbc.
What part of the emissions test are you failing?
Old Mar 30, 2012 | 12:49 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
blue smoke on start up is usually worn valve seals. not hard to change, even with the heads still bolted down.
Old Mar 30, 2012 | 12:53 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
It's failing the three main things its needs to pass, co readings, nx2 and the hco, I probably listed those wrong but I'm on the way to the shop right now to pick up the car and the emissions paper, then I will be able to tell you.
Old Mar 30, 2012 | 12:54 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
How do I go about changing those.?
Old Mar 30, 2012 | 01:08 PM
google search or youtube will help a ton
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Linson
Aug 21, 2015 02:12 PM
wruiz
Aug 11, 2015 02:59 PM
mustangman65_79
Aug 8, 2015 01:18 AM
