How to replace slave cylinder
Old Mar 28, 2012 | 06:43 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Hi there... I tried installing my old slave that was just hanging.. But beibg plastic the screw to bleed it was shreded and wont stop leaking... I headed over to autozone and bought one for the car... How do i remove the hose and things like that? Thanks in advance
umm... has anyone ever replaced your slave with one from autozone? i dont see how to cap that big hole
Old Mar 28, 2012 | 07:20 PM
pvr007's Avatar
Engine: 305 TBI
Re: How to replace slave cylinder
Bump
Old Apr 12, 2012 | 10:05 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
have you found anythig out yet? and i think you may have gotten the wrong one cause i had got mine from autozone and it looked identical to my original one.
Old Apr 13, 2012 | 01:16 AM
pvr007's Avatar
Engine: 305 TBI
ok heres the thing.... the in line goes where the yellow cap goes.... the screw one on the rights is the bleeder... thing is mine was so dirty i coudent figure out where the screw was... but it was a pin.. right where the inline goes theres a pin that holds it... also dont forget to put in the 0 ring seal or it will leak... you will have to take the pin out and its a pin in the ***.. actually this one is better quality then the plastic one..
Old Apr 14, 2012 | 11:43 AM
Car: '90 Camaro
Engine: 305 tbi
You know what the day i replied is the day mine went out lol now i have the same one as you and that oring boy did it make me mad. Well glad you figured it out.
Old Apr 14, 2012 | 10:41 PM
pvr007's Avatar
Engine: 305 TBI
yup.... trick ... pumping the clutch wont be enough to get air put... put the clutch and also push the rod into the cylinder.... problem is the in line and the bleed nut are right next to each other and it totally skips the inside cylinder
Old Apr 16, 2012 | 11:12 AM
Car: '90 Camaro
Engine: 305 tbi
yea im pumping mine right now, i went ahead and replaced my master slave cylinder too. but my pedal has little resistance. but ill figure this out. cause i dont want to thread jack haha
Old Apr 28, 2013 | 10:32 PM
sergio's Avatar
Car: 91 T-am convertible
Engine: 5.0 TPI
Transmission: 5 speed manual
Hi Guys,
I'm in the middle of bleeding my clutch and am having a real hard time.
Is there a specific set of steps to do this?
Old Apr 28, 2013 | 11:49 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Originally Posted by sergio
Hi Guys,
I tried gravity bleeding mine. Didn't work at all.
I tried bleeding it the way we do brakes.... didn't work very well.
Basically the best thing you can do is just pump it and pump it and watch for bubbles coming up through the master cylinder resevoir. It actually self-bleeds over time.... USe the bleeder to make sure you get all the air out between the slave and the master, but to get air out of the slave itself will just take a while.
I thought I had mine bled enough (changed from a T56 slave to a larger diameter one) and it was supposed to be a softer pedal, so I wasnt sure when it was "normal". I set hte car up on jackstands, turned it on and checked for clutch drag in gear at the rear wheels when thecar was in the air and had none so I called it good. Over the next couple of weeks it stiffened up quite al ot.
So just do what you can, then check it on stands and see if it's close enough to be drivable. As long as the clutch isnt dragging, it's not going to hurt anything.
Old Apr 29, 2013 | 04:57 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
I had to take my slave cyl off and pump it by hand to get all the air out of it before I could even begin to bleed it. Fortunately pumping by hand bled it most of the way. Took two strokes by hand to do it really easy to do.
Old Apr 30, 2013 | 11:23 PM
sergio's Avatar
Engine: 5.0 TPI
Guys,
I finally got it. It was air in the line.
Here is what I did:
1-filled the slave cylinder with dot 3 fluid ( with bleeding screw loose).
2-install fluid line to slave cylinder.
3-mount the cylinder.
4-fill the reservoir with fluid.
5-wait until the fluid drains out of the bleeder.
6-tighten the bleeder (at this point you have the slave and line fully bled).
7-start pumping the master (short strokes) until you feel pressure.
If this does not work it is becaause you pumped air from the master into the slave.
8-have some one hold the clutch pedle in while you manually push in the slave, open the bleeder.
9-Repaet step 8 again.
While doing this make sure you the reservoir always has fluid in it.
also check out this site, it has great info.
http://www.perfectionclutch.com/tech-support.htm
Old Nov 21, 2013 | 01:26 PM
The Eager Teen's Avatar
Car: 1985 Trans Am
Engine: 1990 Corvette L98 w/ ported 081s
Transmission: Stock Non-WC T5
Axle/Gears: 9 bolt w/ discs
What size bleeder screw is that?
Need to replace the rounded out allen key screw with a proper bleed screw.
Old Nov 21, 2013 | 04:15 PM
Car: 1985 Trans Am
Found it.
5/16-24 or M8-1.25
Old Nov 21, 2013 | 06:58 PM
Car: 1992 Camaro RS
Just a thought... perhaps if you crack open the bleed screw and let it gravity bleed BEFORE you snip the cables holding the slave piston fully retracted, you wont have to bleed it the hard way?
Does anyone think this would work?
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
db057
Aug 22, 2015 08:17 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
