Will a hotter plug make a difference?
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
I've heard that it can but never tried it for myself, anybody know?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Will a hotter plug make a difference?
Plug temperature is the temp on the tip of the plug. What temperature the plug is depends on a lot of factors but the goal is to have the tip temp operating in the same range. Adding compression or boost requires a colder plug because of the hotter temperatures created in the combustion chamber. In the end, the tip temp will still be in the proper operating range even though it's a colder plug.
You want to run as cold a plug as possible. Too cold and the plug fouls up. Too hot and the tip burns off. Running a hotter plug in a basically stock engine won't change anything unless you're burning oil and the plugs are fouling up. The hotter plug will help burn off those extra deposits. It's a bandaid fix.
