Am I missing something or Buying the wrong thing.....
Old Mar 31, 2012 | 04:34 PM
acerocks666's Avatar
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
Hey guys I am having a small yet frustrating problem. Car is a 83 Z28 that was originally a 5.0 HO with manual but has since been converted to a 350 and th350 tranny. Last summer when I had the engine all apart my oil dipstick and tube got bent up and twisted. No problem I will just get a new one I thought anyways. I have bought 2 dipsticks in the past week and neither of them were even close to lining up right. The first one I got was a MR. Gasket #6238 which is for our years but maybe not for a 350. The second one I bought off of ebay and it said it worked for 80 and up 305-350 engines with passenger side entry. Got it today and again not even close to lining up. Am I missing something here can you guys maybe point me in the direction of dipstick and tube part #'s that will work for me and just so I am clear the dipstick enters the block right behind the starter correct?....
Thanks for any help...
Old Mar 31, 2012 | 04:51 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Am I missing something or Buying the wrong thing.....
Get the lokar universal. Also the tube on my 86 is on the passenger side same with the 89. I am wondering if you have the trans dipstick confused with the oil?
Old Mar 31, 2012 | 05:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by acerocks666
I have bought 2 dipsticks in the past week and neither of them were even close to lining up right...
Lining up where?
In front of the starter motor
On '80 -85 with pass side stick ; , up on the side of the block by # 6 plug.
There is a raised casting on the side of the block with a hole for dipstick at top
On '86+ ; same position but lower down on the pan rail so a longer dipstick tube required
Old Mar 31, 2012 | 05:30 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
I ran into the same problem with my 92 when I rebuilt it. No aftermarket stick would work, so I went to my local Chevy dealer and they still stocked it, so I was in luck. Cost me $49.00, but it was worth it.
Old Mar 31, 2012 | 05:47 PM
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
vetteoz when I say it is not lining up I mean the end of the tube is no where near the entry point on the block. mmadden55 do you have a part # for the lokar or jtsk for the gm thanks....
Cornholio7979
Sep 20, 2018 02:31 AM
Cleotiz
Jan 6, 2018 08:56 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mddaniel
Sep 8, 2015 05:16 PM
86White_T/A305
Aug 17, 2015 12:16 AM
