A/C guys- idle orifice tube problem?
Guys- I just replaced the compressor and dryer and recharged a system (R134). She's cycling just fine and pressures, at least on the low side (I only have a gague on the filler hose), are right. But it's not getting very cold. Verified that the hot/cold selector system is working right.
I'm starting to wonder if I've got an orifice tube problem. Or could the evaporator be plugged up??
Now, on this particular vehicle I have a built-in comparison method- it's got front and back A/C systems (no, you caught me, not a Camaro- an early 90s Suburban). The front and back both run off the same compressor and how the system functions is otherwise identical to a late 3rd gen Camaro A/C system.
The rear A/C will freeze you out. The front is kinda weak. And the dryer bottle that comes off the front evaporator doesn't get very cold.
I don't even know if the rear system has it's own dryer and orifice tube, but for sure the compressor and the other shared parts aren't causing the problem It's a front system only problem we're having.
Any ideas or diagnostic methods you guys could offer up? Thanks in advance.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: A/C guys- idle orifice tube problem?
High and low pressure readings with the AC on max and the engine at a high idle? You'll need to see both pressure to see what the system is doing. Does the high side pressure increase when a piece of cardboard is placed in front of the condenser?
db057
Aug 11, 2015 10:11 PM
