AN fitting size -5??
Old Apr 3, 2012 | 01:18 PM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
I am doing a modification on my fuel system so I am going to convert my old 3/8 fuel line and the 5/16 fuel line to AN. and run hoses from the firewall to the fuel rails.
I have bought a flaring tool so I have that in hand. Now it is time for buying the fitting and I can find everything except the size -5 in AN fitting. Are there actually anything called AN -5?? Or do I have to run a size smaller (or bigger) to get my lines converted. I can only find AN -4, -6, -8 and so on...
Would have been nice if there is the size -5 somewhere because that fits correctly to the 5/16 return line.
Old Apr 3, 2012 | 02:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: AN fitting size -5??
-5 fittings exist but are a little uncommon. Use a -5 tube nut and sleeve and a -5 to -6 adapter with -6 hose.
Old Apr 3, 2012 | 03:15 PM
Ok..Thanks.
Do you have any link to a site which sells theese??..
I really can't find them anywhere..Summit..Jegs...ANfittingsdirect.com
No one has those...
Old Apr 3, 2012 | 04:29 PM
I did actually find it on Jegs...Just had to look for a while.
But thanks anyway Apeiron
Old Apr 3, 2012 | 04:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
http://www.summitracing.com/parts/EAR-581805ERL/ and http://www.summitracing.com/parts/EAR-581905ERL/
http://www.summitracing.com/parts/EAR-991907ERL/
Old Apr 3, 2012 | 04:39 PM
Ahh..I guess I am having a rush when I am searching
They are anyway ordered now and are on it's way to Norway.
Thanks for the help..
Old Apr 3, 2012 | 04:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Remember that to flare the tube for AN fittings you need a 37 degree flare tool, not the much more common 45.
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
tom1985
Apr 19, 2016 07:55 AM
toronto formula
Nov 10, 2015 06:17 AM
wruiz
Aug 13, 2015 09:07 PM
knight72
Aug 10, 2015 09:32 PM
