distributer problems
Old Apr 8, 2012 | 08:51 PM
oilfieldtrash7's Avatar
my 85 camaro w/305 just died wouldnt start back up looked around found the distributer was loose took it apart and had some moisture in it as well cleaned it up and reset the ignition timing and it still wont fire (reset the timing using a haynes book) any idea on why it wont start.
Old Apr 8, 2012 | 11:24 PM
Bigdeerock's Avatar
Re: distributer problems
If it was loose ur timing was probably so far off from jiggling around that it won't start. How did u reset timing if it won't start?? My guess would be your 180 out after the reinstall. It is cranking though??
Old Apr 9, 2012 | 10:07 PM
i pulled the distributer and tuned the crankshaft to 0 degrees then reinstalled
Old Apr 9, 2012 | 11:10 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by oilfieldtrash7
i tuned the crankshaft to 0 degrees then reinstalled
On the compression or exhaust stroke ?
Zero comes up twice per cycle
Old Apr 10, 2012 | 10:50 PM
compression. i think know where i messed up i read in a haynes book to point the rotor between 1 and 8 which would spark cylinder 8 instead of 1 now im just waiting for a day off to work on it. then i open another door how do u adjust the timing i know u need a light but do you just rotate the cap clockwise till its perfect or something else?
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
