camaro wont start
Old Apr 14, 2012 | 08:52 PM
oilfieldtrash7's Avatar
camaro wont start
camaro wont start washed the engine then the next day it ran rough started to backfire then died now it wont start at all pulled the distributer was loose. cleaned it up then i forgot which way it went back in so i put the engine on the compression cycle at 0* tdc reinstalled made sure tht the rotor and the #1 plug wire were lined up and tried to fire it up just kept turning over i pulled the #1 plug and checked for spark had spark. any ideas on wht the problem is
Old Apr 15, 2012 | 07:31 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: camaro wont start
Could be 180 degrees out, I have been fooled before by a exhaust stroke rather than a compression stroke. I would pull dist. and try again. [ next time put a plastic bag over your dist. ]
Old Apr 15, 2012 | 11:45 PM
i am positive im on the compression stroke i felt air blow by my finger and i used a screw driver and my timing mark on the engine to find tdc made sure my plug wires were hooked up right and that the rotor was lined up with the 1 plug wire
Old Apr 16, 2012 | 01:45 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
weak spark or fouled plugs?
Old Apr 16, 2012 | 09:54 AM
torque_is_good's Avatar
I gave him the exact same advice on another forum
there is no harm in double checking
Old Apr 16, 2012 | 11:07 AM
i just double checked and even turned the distubuter 180* my plugs are blackened but they look normal. thinking about getting it towed to a mechanic
Old Apr 16, 2012 | 12:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Do a spark plug change, you may have fouled them.
Old Apr 16, 2012 | 04:45 PM
did a plug coil and wire change still nothing
Old Apr 16, 2012 | 04:47 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I said spark plugs.
Old Apr 16, 2012 | 05:06 PM
i did a spark plug change and upgraded the coil and spark plug wires
I finally got it running my timing was to retard.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
