to much psi at idle
Old Apr 15, 2012 | 10:38 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
to much psi at idle
i posted this in the transmission forum and have got no replies.
i have a 355 sbc 700r4 trans, transgo shift kit, corvette servo, uprgaded vane and new sunshell sprag assembly. the issue im having is that at idle im getting the currnet psi:
connected:
p-125
r-200
n-175
d and od-125
2-125
1-125
disconected:
p-175
r-200
n-200
d and od-175y?
2-175
1-175
now what could be the issue? i jerked on the cable about 100 times and no pressure changes.... anybody lead me to correct way?
Old Apr 15, 2012 | 02:54 PM
ex-x-fire's Avatar
Re: to much psi at idle
Whats the symptoms? Slipping tranny?
Old Apr 15, 2012 | 07:33 PM
Engine: 355
at wide open throttle 1-2 it revs up and then catches the gear, and will rev out aboyt 4500rpm
Old Apr 15, 2012 | 07:46 PM
ex-x-fire's Avatar
I'd take a look at the governor. Was the tranny done by a shop? If it was I'd call them up, if you installed it, i'd call transgo.
Old Apr 15, 2012 | 08:01 PM
Engine: 355
ya itwas built by a shop but the guys a dueche bag and wont return my calls. also would the governor cause the high psi? it doesnt change much even pulling the cable
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
