Need a Cam
Old Apr 15, 2012 | 09:27 PM
69442DREAMCAR's Avatar
Need a Cam
I have a 350 motor I pulled from a 92 Chevy Truck that I had a problem with the frame cracking were some of the steering components bolted to it. I have had the truck for a number of years and it ran really good seemed to have a lot of power. I removed with plans to put in a 89 RS I have, got it out and tore it down and found it was a roller motor with 4 bolt mains. I am going to use it with a 670 Holley and weiand intake that I have already. It has flat top pistons with the 4 valve reliefs and the heads will be 65cc, what would be a good roller cam for this engine? The RS already has shorty headers with no cat and 3" duals and a posi 3:23 rear and 700r trans, it would be driven on the street for pleasure not a everyday driver. Would prefer to use one of the GM hipo cams instead of aftermarket.
Old Apr 17, 2012 | 11:40 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Re: Need a Cam
get the LT4 hotcam... it seems to do really well...
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
