Rebuilding an Engine?
Old Apr 19, 2012 | 09:41 PM
Guest
Guest
Posts: n/a
When you guys say "My rebuilt LB9" or "I just rebuilt my engine" what does that fully mean? What all do you do, and does it lengthen the life of your engine?
Old Apr 19, 2012 | 11:38 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Re: Rebuilding an Engine?
Shop online for engine rebuild kits - see what they come with. That's a starting point. Once in there and so inclined the performance increase begins...
Old Apr 20, 2012 | 12:21 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
To me, 'fully rebuilt' means just that. You pull it down completely to bare block, clean, machine, replace, upgrade, fix whatever needs to be done, and you build it back up again.
Then again, one time an acquaintance showed me his 'rebuilt' motor - same as it was the day before but with a K&N filter on it... 'I rebuilt it mate'... the meaning's in the eye of the utterer I guess.
Old Apr 21, 2012 | 01:47 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Rebuilt: It means you broke it down to the to the bare block and replaced the parts needing replaced.
Complete Rebuild: You broke it down to the bare block and heads machined both to get a clean surface to start with. Replaced every part with new parts.
Infested
May 22, 2018 11:56 PM
backtothe80s
Sep 5, 2015 12:39 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
hokis
Aug 9, 2015 03:57 PM
