tapping at 2k rpm
Old Apr 20, 2012 | 03:33 PM
84'transam's Avatar
Car: 1984 Trans am H.O.
Engine: 305.
Transmission: t5
tapping at 2k rpm
hey guys i have a 305ho that i recently installed some comp cams roller rockers into and i get a tapping at 2000 rpms i tightened all of the rockers correctly and i still am having the same problem. it sounds like a rocker arm but it not getting any better or worse. what else could it be?
Old Apr 20, 2012 | 04:04 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tapping at 2k rpm
are these self aligning?
Old Apr 22, 2012 | 10:03 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
If you messed with the exhaust, check your exhaust from the heads to the cats.
Old Apr 26, 2012 | 06:20 PM
84'transam's Avatar
Engine: 305.
Transmission: t5
tunedperformance
i believe thats what i read when i ordered them
Old Apr 26, 2012 | 06:21 PM
84'transam's Avatar
Engine: 305.
Transmission: t5
FtrSpeedy
i never had any problems with the stamped rockers after the exhaust was put in just the roller rockers now are giving me problems
Old Apr 26, 2012 | 06:34 PM
Engine: Lb9
Transmission: M20
double check that they were self centering, you may have a lash issue or a exhaust leak. If these are not self centering and you are not running guide plates you may have already bent some pushrods and you can bent valves.
Old Apr 26, 2012 | 06:36 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Sorry what i ment was an exhaust leak near the heads will give you a tapping noise. Check the roller tips, might have a bad tip.
Old Apr 26, 2012 | 06:50 PM
84'transam's Avatar
Engine: 305.
Transmission: t5
how do i check the tips, just make sure they are moving?
Old Apr 26, 2012 | 06:51 PM
84'transam's Avatar
Engine: 305.
Transmission: t5
alright ill check on those once i get home should have i been running guid plates anyways?
Old Apr 28, 2012 | 12:11 PM
Engine: Lb9
Transmission: M20
To run guide plates you will need hardened pushrods and pull the rocker arm studs and tap the heads for screw in studs and machine the rocker arm stud boss. Self aligning rocker arms would be a better way for you to go than removing the heads.
PLANT PROTECTION
Sep 1, 2001 12:03 AM
chevyguy1969
Jan 20, 2001 12:13 AM
TannerZ34
Nov 29, 2000 08:03 AM
Zepher
Sep 28, 2000 08:23 AM
