1991 GTA cranks but wont start
Old Apr 21, 2012 | 12:48 PM
boomdiggity's Avatar
Hello all. I have a 1991 Trans AM GTA with a 305 TPI and the car will just crank and will not start. The car has spark and fuel pressure but the injectors are just not opening. Have been stumped on this for a little while now and looking for some help.
Old Apr 21, 2012 | 02:05 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Re: 1991 GTA cranks but wont start
My first question is, do you have any codes stored in the ecm? My second question is, how did you determine the injectors aren't opening?
Old Apr 21, 2012 | 02:35 PM
Not sure of the codes and I do not recall them telling me about any codes and for the injectors it will start on starting fluid and we did check the fuel pressure and it is correct. Also we replaced the computer and it fired right up but then died again almost immediatley and just goes back to cranking again.
Old Apr 23, 2012 | 10:27 AM
Car: 1989 Camaro
does it continue to run after you start it with the starter fluid? You could have a failed coolant temperature sensor. It gives a false reading which changes the amount of fuel the ecm thinks the motor needs and presto! No start
Old Apr 24, 2012 | 07:52 AM
Car: 1989 Camaro
Forgot to mention in my last post that if it continues to run with starter fluid being sprayed in it, then the fuel pump probably gave up the ghost
Old Apr 24, 2012 | 01:38 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Another possible thing since it's a 91, is VATS
Old Apr 24, 2012 | 09:00 PM
ZeBatmobile's Avatar
Car: 92 Z28
Engine: 350 (ZZ4 Block) '193 heads.
Transmission: WC T-5
Axle/Gears: 3.42 Posi
VATS won't allow crank. How did you test for fuel? If the car doesn't get spark then it won't fire the injectors... but you're getting spark? Check the injector fuse(s) in the fuse panel?
Old Apr 25, 2012 | 05:35 AM
Did you check the "ECM1" & "ECM2" fuses? (the ones that supply power to the injectors)
Old Apr 25, 2012 | 07:48 AM
Car: 1989 Camaro
That's a good point Sofa. The thing that doesn't make much sense is why it started after changing the computer, and now it's back to square one
bryan623
Mar 22, 2021 06:43 PM
Caspar
Jun 19, 2016 11:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
Street Lethal
Aug 14, 2015 08:25 PM
mizz0313
Aug 12, 2015 06:45 AM
