Smoke only at start up
Old Apr 26, 2012 | 09:46 AM
Russ87ROC's Avatar
Car: 87 Iroc Z, hard top
Axle/Gears: 2.73 or 3.23, not sure...
1987 Camaro IROC-Z, 157,000 miles, 305 TPI.
She starts right up. No hesitation at all. Plugs, cap, rotor, wires, fluids, etc are all new. But...I get a huge puff of smoke out of the tail pipes when I start the car, then it goes away. Here is the odd thing...some times its white and some times is blue/white and smells. Nothing is leaking under the car.
This only happends when the car is cold. If I drive it around, park it for a little while, then re-start there is no smoke.
Just an old enigine or a real problem?
Old Apr 26, 2012 | 09:52 AM
jwdomino's Avatar
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
Re: Smoke only at start up
valve seals leaking
Old Apr 26, 2012 | 09:55 AM
1gary's Avatar
A very high percentage it's valve seals.I like to do the job right and although you can replace the seals with the heads on,I prefer to remove the heads for a complete valve job checking the valve guides at the sametime.
Old Apr 26, 2012 | 10:15 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Originally Posted by jwdomino
valve seals leaking
This is correct
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
