For anybody with a 2 piece rear 168 flywheel/flex Plate
Old Apr 26, 2012 | 09:59 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so just to give u guys a heads up if ur replacing the oil pan or gasket dont attempt to use a 1 piece oil pan gasket get the old style 4 piece one for one u wont be able to get the oil pan out cause the flex plate or flywheel will be to dang big i tried today with the motor in the car using the 1 oil piece gasket an 2 of them failed so i got a 4 piece an a ton of rtv sealer to do the job an i started at 4 o clock an here its now 11 word of advice just pull the motor out alot easier an less time consuming hope this will help out alot of f body people
1992 Trans Am
May 10, 2023 07:19 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
mhatfield 14
Oct 24, 2015 07:48 AM
LT1Formula
Aug 20, 2015 09:36 PM
1985chevydude
Aug 20, 2015 12:29 AM
