Faulty fuel gauge?
Old May 3, 2012 | 07:50 PM
travisgold's Avatar
Car: 1984 Camaro Z28
Faulty fuel gauge?
I don't know if my fuel gauge is working correct or not. When I drove the car home last saturday, I was at a half a tank I let it idle for 5mins while I talked with a friend I looked at my fuel gauge I was at a quater, after a 15min drive I was almost on empty, I drove it for 2 mins I was on empty I shut off the car at a walmart started it 15mins later I was at a quater again.... then I drove to my friends on empty again.... drove home had just above empty, brought it home started it then next day it ran, car completey on empty, put $10 worth just above empty 2 mins later.... empty..... now I let it run 5mins on empty to see what happens, it keeps running.....
Old May 3, 2012 | 08:00 PM
MadSciienTiisT's Avatar
Car: 1985 chevy camaro
Engine: 355 sbc
Transmission: 700r4 auto
Axle/Gears: maybe 3.42s or 3.08s? d'no
Re: Faulty fuel gauge?
mine had done that at one point, i had a bad ground behind my cluster.. knocked it loose when i was installing a light bulb in the dashboard, or the floater in your tank could be real loose? shake your car or jack it up on each side to see if it (the gas gauge) changes, if the needle doesnt change then the floater could be loose.. if it does slighty change or flips around a little rapidly.. could be a loose wire. start touching wires and see if the needle moves as well?
Old May 3, 2012 | 08:51 PM
travisgold's Avatar
thanks for the quick reply! I know when I am went up hills i think it might of shifted. it tends to change allot.....
Old May 3, 2012 | 09:28 PM
Engine: 355 sbc
then it could most likely be a bad gauge or a bad wire.. hit any nasty pot holes lately or anything similiar?
Old May 3, 2012 | 09:35 PM
travisgold's Avatar
Nope she has been sitting in the yard for weeks while I work on her. Just put a dress up kit on it, I have a bunch of amazing wiring issues to deal with on it, (No Hazards, No Backup lights) Something to do with my tilt column probably a bad connection. I call my car the Nightmare T/A since she needs so much work. I love it though!
Old May 3, 2012 | 09:51 PM
Engine: 355 sbc
i hear ya.. most likely wireing issue for you then... i still havent gotten my hazards to work properly.. closest i got was the hazard switch triggering the left directional.. lmao
Old May 3, 2012 | 10:00 PM
travisgold's Avatar
oh geez what is the matter with you haz switch probably the same as me? this is what my car does.... I put the stop haz fuse in and the brake lights turn constantly on, then i put the haz switch on the indicator lights up doesn't flash though and the lights all come on they dont flash, i remove the fuse and hook up the ******* wire for the brake lights and i have brake lights again lmao
Old May 3, 2012 | 10:37 PM
Engine: 355 sbc
its all relays that control that ****... just gatta get the right relays and know where to put them.. which is nearly impossible to accomplish by yourself.. haha
Old May 3, 2012 | 10:39 PM
travisgold's Avatar
oh yes. my friend owned a 1980 firebird, it was his first car he had to sell it since it needed to be inspected and it kept trying to light itself on fire.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
