Vortec or not
Old May 3, 2012 | 08:18 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Vortec or not
First is there a way to tell if the engine is a 350?
Second is there a way to tell if it is a vortec?
Third is there a way to tell the year?
I am buying a motor off this guy and I am taking his word it is a 350, a vortec, and he says it is a new motor.
Old May 3, 2012 | 08:33 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Re: Vortec or not
Behind the driver side head are some numbers. Those numbers will tell you what the motor is. If it is a vortec, it should also say 5.7l back there. What is the motor out of?
Old May 4, 2012 | 01:40 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Vortec or not
Vortec intake manifolds are only held on by 8 bolts. Count the bolts. 2 at each corner, and NONE in the middle area.
Here's an edelbrock Vortec TPI base as an example:
There are 305 Vortecs too, so check the casting number for a 5.0 or 5.7.
Notice you're looking down at the engine, and thats the oil filter on the left that you can barely see. That will help you figure out what you're looking at so go find it.
Old May 4, 2012 | 03:08 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Vortec or not
Same location on opposite side of block will have # 10243880 cast on the block and there will be # 880 cast on each side of the block above the pan rails
If it is a vortec, it should also say 5.7l .
FWIW
All 1 pce RMS engines ('87+ ) have 5.0L or 5.7L cast there
Old May 4, 2012 | 07:44 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Vortec or not
You can also pull the valve cover and see what heads are on it and check to see if they are vortec castings.
Should be 906 or 062, I think there is also a 602
Old May 6, 2012 | 11:59 AM
gregl316's Avatar
Re: Vortec or not
Thanks it's a Vortec. It has a name plate on it and it says year and it says 1999 is it a roller?
Old May 6, 2012 | 07:50 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Vortec or not
T it's a Vortec. It has a name plate on it
As you were told ; Vortec is the name of all GM's truck motors since 85; label means little
is it a roller?
All real Vortecs (96 -00 ) are roller cam
Old May 8, 2012 | 09:24 AM
gregl316's Avatar
Re: Vortec or not
It is a Vortec the casting numbers are rite. It does say 5.7 on the block too. Now is there any way of telling if it's a GM performance motor? I beleave it is just from the outward appearance and what it came out of and the guy I bought it from said it has
300+Hp.I am going to buy the smog performance intake smog headers and my tuner says to put 1.6 roller rockers on it. Should I get a TBI unit from a truck equipted with a 454? The Holley looks nice but all the forms say it isn't worth the money. I still need the knock sensor from a 350 rite? Do I still need to put an ESM from a 350 too? Are they expencive I plan on buying them new. I don't trust junk yard electronics. My tuner charges 175 for a chip and I suppose he tunes it too. He said it would take him 3 or 4 times to get it rite and he said don't start it for the first time with out him. I'm new to this so any input is gladly excepted and listened to. So feel free to chime in and tell me if I'm doing anything wronge or hell if I'm rite.
Thanks Greg
Old May 9, 2012 | 12:31 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Vortec or not
While the same basic block was used for other GMPP crate engines ;
if yours still has Vortec heads then it may be the Vortec 330Hp HO version that just has a bigger cam
http://paceperformance.com/i-6255511...te-engine.html
What outward " appearance " ?
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
Liveaction
Sep 17, 2015 06:29 PM
