Guess what this is!
Old May 4, 2012 | 06:35 AM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Guess what this is!
i dont know what it is... iddle air valve? vacum regulator... heck idk
all i know is that if i dont cap it it my engine runs like crap.... but when i do cap it car iddles really low sometimes stalls when cold... once in gear and hot it runs fine... so im guessin its iddle air? thing is... wtf does it conect to?
Old May 4, 2012 | 06:40 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Guess what this is!
it appears to for intake vaccuum. maybe to the pcv valve? yea, thats gotta be a major vaccuum leak.
Old May 4, 2012 | 06:43 AM
pvr007's Avatar
Engine: 305 TBI
nah pcv is hooked up allready... checked the vacum diagram for this car all is conected.. canistor pcv EGR... only thing not is the intake valve that switches from cold air to hot air... hot being from the intake manifolds... and the smog pump... but smog pump just sends hot gasses from manifolds to cat.. so ill worry about that later
Old May 4, 2012 | 06:50 AM
It's just a fitting... the vacuum line that carries vacuum to the car's accessories (specifically, the HVAC control head) hooks up there.
Old May 4, 2012 | 06:54 AM
pvr007's Avatar
Engine: 305 TBI
soo i should just leave it pluged?
Old May 4, 2012 | 07:22 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
OR... reconnect the vacuum accessory system up to it so that your HVAC vents and cruise control can operate correctly.
Old May 4, 2012 | 07:53 AM
pvr007's Avatar
Engine: 305 TBI
and how would i do that??
Old May 4, 2012 | 11:25 AM
naf's Avatar
naf
Reconnect and/or replace the missing parts. A u pull it JY is a good source of pieces/parts and you can usually figure out how they back on after seeing how they came off. At least two near you: Ecology, and pick a part on energy way, both in Chula Vista, CA
Old May 4, 2012 | 01:22 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
On my 305 TBI that vacuum port goes to my MAF.
Old May 4, 2012 | 03:00 PM
pvr007's Avatar
Engine: 305 TBI
well on my engine diagram, the MAP goes behind the TBI... someone correct me if i am wrong
Old May 4, 2012 | 04:28 PM
antares57's Avatar
My bad...I meant MAP. I've got an "E" 305 TBI and I was looking as the vacuum routing diagram was set up.
Old May 4, 2012 | 05:38 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The MAP connects to a port at the rear of the throttle body. Sofakingdom is correct. That fitting is for accessory vacuum. If you don't use the accessories that it was connected to. Keep it capped.
Old May 5, 2012 | 02:16 AM
pvr007's Avatar
Engine: 305 TBI
ok i will... also... um... my smog pump... how do all those things get hooked up... is it just the air coming from the headers pumped to the cat.. or is it hooked up to the egr.. what i need i someone with a 88 tbi vin E just like mine so that i can take a look at there hook up... you see i got this engine torn apart... all ive done till date has been thanks to alldata
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
