fuel pump dead?
Old May 6, 2012 | 01:36 AM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
fuel pump dead?
well i recently gotten my car back from the shop for a trans problem. well i got the car back and a day later my fuel pump wouldnt prime, so my car doesnt start it turns over but no start. now before i tear apart my rear to get to the tank, what should i check? i checked my relay already and still didnt prime or start. i also took my iacv out and cleaned it. i just wanna know what i need to look at or check before tearin out the rear end. thanks in advance!
Old May 6, 2012 | 01:50 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel pump dead?
fuel pump fuse would be obvious starting point
if that checks out then run 12V to the direct pump and see if it runs ;
if it does then your problem is with pump control , not the pump itself
Originally Posted by DiabolicalRS
i checked my relay already .
For what ?
Does it have full time power on one of the heavy wires?
Does it get power on one of the smaller wires when key is switched on ?
Will pump run if you jumper the relay plug???
What did you "check " ?
Old May 6, 2012 | 11:08 AM
Car: '90 Camaro
Engine: 305 tbi
Re: fuel pump dead?
can u tell me where the fuse is because i looked at my fuse box and just seen inj1 and inj2 fuses no fuses that said pump. and the pump control wheres that too?
Old May 6, 2012 | 11:43 AM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Re: fuel pump dead?
Also try checking your Oil Pressure Switch. it is a sensor right above the Oil filter. if the oil pressure drops below a certain point the fuel pump quits. and if it is bad, the fuel pump wont prime until you spin the engine over enough times that it builds up oil pressure. if that doesn't make sense let me know i can try explaining it better.
edit: just noticed you have a '90 camaro. not sure if the pressure switch was on those or not. if you don't know what i am talking about, let me know, i can explain it better and maybe include a pic.
Old May 6, 2012 | 11:47 AM
Car: '90 Camaro
Engine: 305 tbi
Re: fuel pump dead?
tyhat does cause i first had this prob at wal mart i had to try and get home so i kinda crank it a few times "sayin please baby get me home" lol and it started after the fourth attempt. ran fine all the way home kinda lackin lil power. as soon as i got home and turnt it off. it wouldnt turn back on. i shal check that out thanks man
Old May 6, 2012 | 12:17 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Re: fuel pump dead?
I had the car die on me while driving because of this. thought it was the fuel pump. 6 hours later i got the pump out and realized it was good. then i tore apart the interior following the power line thinking it was broke because i wasn't getting any power to the pump. needless to say i spent the better part of a day pulling the rear end and interior apart on my car looking for a problem that was by the oil filter. i went to Auto Zone to see if any of those guys had any ideas. they didn't but a random customer overheard me and told me what it was. I really got lucky that I ran into that guy.
I know what you mean though, every time i get in the car I'm saying "please baby, just start for me." She really has a mind of her own and can be stubborn sometimes. Acutally my brother was trying to start the car to move it around the yard las summer and it wouldn't start at all. I walked out and turned the key and she fired right up. She must just like me
Old May 6, 2012 | 12:22 PM
Car: '90 Camaro
Engine: 305 tbi
Re: fuel pump dead?
shoot i would have been mad if i were you. like the saying goes "if its not the one thing, its another"
Old May 6, 2012 | 12:25 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Re: fuel pump dead?
Ya i was pretty ticked off but after i got it fixed I went for a nice drive to cool down
Old May 6, 2012 | 01:52 PM
Car: '90 Camaro
Engine: 305 tbi
Re: fuel pump dead?
does any one know where that fuse is located or if it just vanother name for it and also the pump control switch?
Old May 7, 2012 | 03:46 PM
Car: '90 Camaro
Engine: 305 tbi
Re: fuel pump dead?
turns out my battery was pretty low so now i have a red top optima in. its always the simple things that you kinda look over.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
