1988 L98 cam question
Old May 15, 2012 | 01:17 PM
Patrickh's Avatar
Hey guys i just joined, been reading the forum a while and made the jump to a carbueretor from a TPI. However i needed to ask the experts whether or not my stock cam has the fuel pump lobe/eccentrics needed to run a mechanical fuel pump, year model is 1988.
Thanks for the help!
Pat
Old May 15, 2012 | 06:29 PM
Damon's Avatar
Re: 1988 L98 cam question
It should. 1990 is when the fuel pump lobes began disappearing off of factory production line cams in the small block.
I've worked on quite a few 87s and they all had a fuel pump lobe. The cam out of a 92 I have doesn't have the lobe.
Old May 15, 2012 | 08:00 PM
Patrickh's Avatar
Thanks for the info! Put a push rod in before checking the forum and turned the engine over by hand, seems to go in and out about a quarter inch, this is good news! dont need the electric fuel pump!
Thanks,
Pat
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
