No power to starter when jumped / battery good
Old Apr 17, 2012 | 09:14 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I've had nothing by problems the last two weeks. The vats died, then I believe I fixed that with another computer and vats from another camaro. It started and ran fine, then a couple hours later it wouldn't. We had the enable relay jumped, and for some reason it just toasted that wire. Today we tried jumping the starter directly and it seems there is no power getting to the starter at all. We jumped the terminals and nothing happened. The cables are tight and everything. No hint of a spark. We are all completely lost as so what is going on. Any help? I need this fixed a week ago.
Old Apr 17, 2012 | 10:44 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: No power to starter when jumped / battery good
The main batt terminal on starter or the solenoid terminal ?
Old Apr 18, 2012 | 05:39 AM
chevydrvr's Avatar
I Julped from the terminal that had the battery cable attached to the starter solenoid to the terminal next to it. I didn't see any other place that would make sense.
Old Apr 19, 2012 | 04:55 AM
chevydrvr's Avatar
Okay, we found out that the starter is getting power. It just isn't getting a signal from the ignition switch. I'll try another one today and see if that works, if not I have a vats bypass on the way in case it's just that too.
Old Apr 19, 2012 | 09:59 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Won't help if your problem is with
Ign switch
starter enable relay
or starter wiring from the Ign switch
If you can jump the starter ( key on ) to crank the engine and the engine fires up;
it is NOT A VATS PROBLEM
Old Apr 19, 2012 | 11:11 PM
Bigdeerock's Avatar
Had a similar issue not too long ago turned out to be the fusible link bet the starter and the ign switch. Repaired and she started like a champ. May be worth looking at if u have these links in ur car.
Old Apr 20, 2012 | 05:12 AM
chevydrvr's Avatar
vetteoz - I understand that...I ordered that because I still have a security light and I want to install it after it's running anyway to avoid future problems. I need to shim the starter for it to crank.
Bigdeerock - I check all the fusible links and they are all intact.
Old Apr 20, 2012 | 09:24 PM
Bigdeerock's Avatar
Well it was just a thought. Btw if the covering is still on the fusible link and it looks good it doesn't mean it's good. So theoretically they could be "in tact" and still be bad.
Old Apr 21, 2012 | 01:30 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
the fusible links are all intact.
but did you put a DVM on them to see if they past current through ?
not something you do a visual check on
Old May 15, 2012 | 07:38 PM
Slowpoint0's Avatar
Car: 1986 t/a
Engine: Lg4 305 carb
Transmission: 700r4 auto
Axle/Gears: 2.73 posi
Hi,
I have similar prob on my 86 trans am lg4. Batt died. I pulled it out to bench charge it.
All charged put back in. Reads full. All lights work but nothing when I turn key to start, no crank no click, checked wires from removing batt, thought maybe something broke or came loose. Can't find problem
Old May 15, 2012 | 09:03 PM
chevydrvr's Avatar
In my case it ended up being the neutral safety switch. I jumped it and it started right up. Then I decide to go to the store the next day and the starter dies haha. Changing a starter in a parking garage is fun.
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Aug 13, 2015 12:59 PM
milk
Aug 10, 2015 06:26 PM
