Bad starter? 86 IROC
Old May 16, 2012 | 01:50 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
So yesterday i went to start my car after getting done with a car wash and it didt crank so i pop the hood and the positive was melted off the battery it was comepletely trashed the battery just melted when the positive hooked up so i threw a new battery in it and it still wont start i tried banging on the starter and it didt help all it doesnt it kinda click but doents turn the motor over, im going to replace the starter tomoro does anyone think it could be anything else or am i right?
Old May 16, 2012 | 04:04 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: Bad starter? 86 IROC
Is the new battery fully charged?
Did you replace the wire going from the battery to the starter?
Old May 16, 2012 | 04:34 PM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
The battery had a good charge there was no problem there, i could use all the electronical things in my car. So thats what makes me think its the starter
Old May 17, 2012 | 04:57 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
It could be the starter but as G-reg said has the cable been replaced. If not it could easily not be giving a good circuit for the high power that the starter needs.
Old May 18, 2012 | 02:07 PM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
well the problem is kinda fixed the car will start now but only when it wants to other wise all it does is click and then if im lucky on a turn of the key it will start im thinking it has to do with a conection on my battery
Old May 18, 2012 | 02:23 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
If you end up getting a starter, something to consider is one the Corvette uses, but I don't recall which one. There is a thread that tells which one,
either LT or LS.
Sorry not much help, good luck
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
mhatfield 14
Oct 24, 2015 07:48 AM
mustangman65_79
Aug 11, 2015 03:17 PM
milk
Aug 10, 2015 06:26 PM
