hesitates when i step on gas hard
Old May 17, 2012 | 05:40 AM
ljmrtz's Avatar
i have a 88 irocz 350 l98 and 2 days ago i checked the water and oil and both were empty i had just done a oil change two months ago and had recently put water a week ago now yesterday when i was low on gas i took a sharp turn and stepped on it instantly and car didnt respond now today when i step on it too hard at any speed or take off it hesitates and will go and stop until i let off gas could it be my fuel filter got clogged up???Im new so i dont know much about engines or anything so any help is greatly appreciated
Old May 17, 2012 | 06:09 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: hesitates when i step on gas hard
Please use punctuation so we don't have to work so hard to read about your problem.
Were you low on fuel when you rounded the corner? You may have sucked air and damged a pump that might already be weak. But the filter is a good place to start, when did you change it last?
And you should check your oil more than every 2 months. Driving without water and oil is really bad.
Old May 18, 2012 | 12:16 AM
ljmrtz's Avatar
Yes I was low on fuel almost empty. The last time I changed it was about4 months ago. I bought the filter already and I'm going to change it out tommorrow hopefully it fixes the problem thanks. And by pump you mean fuel pump?
db057
Aug 22, 2015 08:17 PM
crazynights
Aug 21, 2015 06:53 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
