83 305 4bb no start
Old May 17, 2012 | 06:29 PM
Cody302's Avatar
Car: 1984 Camaro Berlinetta
Engine: Chevy 305 4bb
83 305 4bb no start
Hey ive got an 84 Camaro with a 305 and a Quadrajet.
Last time i drove the car it overheated so i replaced the radiator because it had a leak, as it turns out.
Ever since it overheated i cannot for some reason get it to start.
Just recently ive repaced the cap, rotor and coil. I also took the ICM and had it tested. Its good.
Checked so far, ive got power, spark and fuel
I'm really getting frustrated. Anybody have any suggestions?
Old May 17, 2012 | 08:14 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 83 305 4bb no start
could check if cam out of time with crank(chain jumped)
check for plugged catalytic converter(if present)or other
plug in exhaust.Also recheck that spark timing and
firing order are correct and that plugs arent shorted.
Does car pop or chuff any while trying to start?
Old May 18, 2012 | 12:19 PM
Cody302's Avatar
No it doesn't. All it does is click like it would with a dead battery but I had that tested at autozone and it's fine. The cell is good and it has no problem holding a charge
Old May 18, 2012 | 02:44 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
If it's clicking, then the starter's not getting the power it needs to turn the engine over...check your battery cables for corrosion. Could be a bad ground as well. If the car had jumped time, the starter would still at least turn the engine over (but skip around on the broken/missing timing gear teeth while in the process).
Old May 19, 2012 | 12:25 AM
Cody302's Avatar
Should i rip out the starter and have it tested? Or do you think that would be a waste of time?
Old May 19, 2012 | 06:56 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Take all of your spark plugs out and observe the condition of each. See if it will turn over with the plugs out, maybe with a light shot of WD 40 in each hole. Make sure y our coil wire is disconnected when you crank it with the plugs out.
Old May 19, 2012 | 08:34 AM
Cody302's Avatar
I just had replaced all the spark plugs before i did the cap, coil and rotor
Old May 19, 2012 | 09:16 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Well if it's not even turning over, it's the job of the starter to do that. Sounds like your solinoid is getting power (it's clicking) - so yeah, have your starter tested. If it turns over and doesn't start, then it's another ball game. But make sure your batt cable contacts are clean both at the battery and the starter first.
Old May 19, 2012 | 11:41 AM
naf's Avatar
naf
And since then I understand that it overheated and now won't turn over?
The motor may be locked up. It could be seized up or the cylinder walls may have become washed somehow. If the starter worked fine before, the overheat episode shouldn't have affected it. The episode may, however, have affected the pieces/parts that the starter motor is trying to turn.
Try removing all of your spark plugs and observing the condition of each. See if it will turn over with the plugs out, maybe with a light shot of WD 40 in each hole. Make sure your coil wire is disconnected when you crank it with the plugs out.
Old May 19, 2012 | 01:40 PM
Confuzed1's Avatar
Car: 83Z28 HO
It's possible you blew a head gasket when you overheated it and a cylinder could be waterlocked since water doesn't compress. Is it even trying to turn, or just clicking?
Old May 19, 2012 | 03:28 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Can you physically spin the engine over? Start yankin belts off too I've seen locked up alternators cause a no crank.
Old May 22, 2012 | 06:44 PM
Cody302's Avatar
it tries turning
Old May 22, 2012 | 09:14 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
at this point might as well pull all the plugs and the
belts and make sure the engine turns by hand and
no coolant in the cylinders-if you got it really hot and
boiled it dry,could have a cracked head.
Bad starter could be the problem too-even if it runs ok
out of the car,could have broken connections or stuck
or worn brushes making it crank weak.
Jake_92RS
Jan 28, 2020 10:37 PM
apo_bailon15
Mar 28, 2016 05:20 AM
justin57
Aug 20, 2015 07:05 PM
drathaar907
Aug 6, 2015 04:20 PM
