fuel pressure question
Old May 20, 2012 | 05:14 PM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
How long should presssure hold in the system? Mine holds for less than 45 seconds and i have smelled fuel a few times after some WOT bursts, but cant find any leaks.
Old May 20, 2012 | 08:42 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: fuel pressure question
You talking about how long it should hold after priming the pump or shutting it off right? 30 seconds, so your ok there.
Wheres the fuel smell come from?
Old May 20, 2012 | 10:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
30 minutes more like it
More important question is what pressure does it drop to?
If pressure drops low straight away ( less than 5 min ) either fuel reg or one way valve in tank is faulty
https://www.thirdgen.org/forums/tpi/...rops-when.html
https://www.thirdgen.org/forums/tpi/...ero-right.html
Old May 21, 2012 | 08:13 AM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
This is what I thought. It drops down to about 8-10 lbs. within 30-45 seconds and then slowly drops to zero over the next minute or two. It holds rock steady at 32 psi while idling with the vacuum line hooked up to it.
The fuel smell would seem to be coming from under the hood and only happened when I got on it hard and then the smell would fill the car for a minute. It only happened a few times and I haven't noticed it in a while, but my fuel economy seems to be really bad ever since then. I checked my injectors for ohms and leakage and I don't see anything leaking anywhere. BUT, when I took my fuel pressure gauge off yesterday and turned on the key, the schrader valve was stuck open and spraying fuel everywhere. I took a screwdriver and pressed it in and released it and it sealed up, so I'm wondering if it was leaking.
Old May 21, 2012 | 09:11 AM
Black88Z's Avatar
Really? I was told it should hold for 30seconds after priming or shutting the car off. Idk where they got that from. Glad you caught it though vette lol
Old May 26, 2012 | 04:08 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Ok, did some playin around and here is what i found out. Clamped the return shut and when i turn on the key it shoots up to 65 psi and as soon as the pump kicks off it quickly drops. Leaky injector? I see no leaks externally.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
