Takes forever to fill gas tank?!?
Old May 25, 2012 | 11:50 PM
91blue5.7tpi's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4th gen..3.23 posi
When I fill the gas tank, i have to go really slow or the gas just spews back out of the filler neck. It is only a minor annoyance so if it never gets fixed then so be it, but it sure would be nice to lock it in, instead of manually holding the pump the entire time.
Anybody have any ideas as to why this happens or ideas on how to fix it? Thanks for reading
Old May 26, 2012 | 05:51 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Takes forever to fill gas tank?!?
Just a theory:
Check behind the spring loaded door where the pump nozzle is inserted.
There should be an internal 1/2" diameter vent pipe inside the filler neck running down to the bottom of the tank along the top side to allow the vapor to escape while filling. Should it get clogged it may cause the tank to burp which will make the pump stop flowing.
Old May 26, 2012 | 07:35 AM
cliff1970's Avatar
Car: iroc z
Old May 26, 2012 | 08:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Just for the sake of more info, there is a recall for your car.
https://www.thirdgen.org/forums/body...call-read.html
JamesC
Old May 26, 2012 | 01:19 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
That recall seems to be year specific, but my '88 had a crack almost completely around the neck allowing condensation to entire the tank and ruin it, fuel rails, regulator, all injectors and the fuel lines. Mine being so severe was due it being driven mostly on weekends, giving it plenty of time to make rust and varnish.
Raul
Old May 26, 2012 | 07:34 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I know of two ways this can occur. The tank filler neck was cut and then spliced with a rubber hose. Or, the CCP line to the vapor pressure valve is plugged.
RBob.
Old May 26, 2012 | 08:46 PM
Car: 1991 Z28
Engine: 5.7 TPI
Thanks for the replies, I'm going to check on those right now and will report back asap. Thanks again!
Old May 26, 2012 | 08:57 PM
Car: 1991 Z28
Engine: 5.7 TPI
well RBob, you were right, at least partially. the filler neck is connected vial rubber hose. I dont however know if it was b/c of a splice or to cover a crack/leak. I dont see a vent hose at all so im not sure if it was some sort of hack job or what but it will have to wait until daylight tomorrow. Thanks guys for pointing me in the right direction
Old May 26, 2012 | 09:19 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
JamesC
Never knew that. My old '91 RS LO3 never had any such problems, but my '06 Sierra does.
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
