88 Insturment Gauges in 82Z.
Old May 24, 2012 | 05:11 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Not sure where I should post this, but here goes...
I'd like to install 88 Camaro inst panel (speedo/tach) in my 82 Z-28.
After searching/reading most of the night last night, I believe it will plug and play, but I'd like to be sure. Both are cable driven speedos.
Old May 24, 2012 | 05:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 88 Insturment Gauges in 82Z.
If you try to swap the entire clusters the warning lights will all be in the wrong positions, but you can take the speedo and tach heads out of the 88 cluster and put them into your 82 cluster.
Old May 24, 2012 | 05:22 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
That's what I needed to hear.
Thx Apeiron!!!!!
Old May 24, 2012 | 05:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's assuming you had a gauge cluster in the 82 to begin with...
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
