Starts, runs rough, stalls, then no start.
Old May 24, 2012 | 08:53 PM
Crudsturbo's Avatar
Okay I am driving myself crazy and maybe I am not looking in the right spot. 85 Z28 305 TPi when it sits it will fire up run rough and then cut off. Will try to start on next crank but then cranks like its not getting spark. But it is getting spark which is crazy, getting fuel, but will not run. Not getting any codes. TPS set at perfect setting. Please help.
Old May 27, 2012 | 06:48 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Starts, runs rough, stalls, then no start.
What's your timing set at? What is your fuel pressure? Have you checked your injectors, swapped fuel filter, and checked your MAF/MAP sensors yet?
Old Oct 27, 2012 | 08:27 AM
310cid's Avatar
Car: 92 camaro
Engine: 406
What problem did u find wrong with it
Old Oct 27, 2012 | 08:34 AM
Crudsturbo's Avatar
A little complicated but through Alldata I was able to determine it was the ECM is bad. It it sending a bad signal to the MAF. But a new one is 55 or I can pay to have my 91 ECM Vats disabled and when I swap the motors it should run fine.
Old Oct 27, 2012 | 10:56 AM
310cid's Avatar
Car: 92 camaro
Engine: 406
Did ur check engine light stay on with key on position
Old Oct 29, 2012 | 09:33 PM
Crudsturbo's Avatar
Yes it has always stayed on and with a code 33 which is MAF sensor or circuit malfunction. Going through the diagnostic procedures I found the ECM isnt sending the correct voltage to the MAF.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
