Cam install
Old May 31, 2012 | 05:27 PM
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
Cam install
Ok so I just got my cam today.. Part # cl12-212-2 ordered it from summit. Installed the cam and everything is good so far. Then went to put the cam locking plate on thats when I had problems. The new cam is slightly bigger then the hole for the cam locking plate. I ordered it for a gen 1 styke so itll have the fuel pump lobe cuz im running a manual pump and my old cam did not have a fuel pump lobe on it. Anybody know anything about this? Is it as simple as going to the junkyard and getting a cam locking plate off an older 350? I got a 91 block
Old May 31, 2012 | 06:51 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Cam install
Originally Posted by camaro211z28
I got a 91 block Part # cl12-212-2 cam
You are installing a old style flat tappet cam in a new style roller cam block.
Flat tappet cams don't use a retainer plate , they have no groove on the front for it
Hope you have flat tappet lifters now ?
Old May 31, 2012 | 07:53 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Cam install
Either toss the retaining plate, or better yet, return the non-roller cam and find a roller. The closest low-budget match for that 12-212-2 would be: http://www.competitionproducts.com/E...uctinfo/E1135/ And when you figure in the cost savings with not needing break-in oil, and not needing to do the extra break-in-oil change 5 minutes after break-in ( rollers don't need it ) it's really no extra cost.
Old Jun 1, 2012 | 07:48 AM
Car: 92 camaro RS
Re: Cam install
Yea I was doing some research and the snouts are different. I called a local machine shop to ask hpw much to grind the snout down so I can use the retaining plate. Its just 30 bucks. but I guess itll be fine without it. It work without one for years back in the day. Should I get a cam button tho or just put it in and leave it alone? Im not worried about the oil, I work at a shop so I can do a couple of oil changes for free
Old Jun 1, 2012 | 07:56 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Cam install
Only roller cams need the plate because roller lifters don't hold the cam in place.
Flat tappet cams are machined so the lifters force the cam to the rear so
nothing extra is needed.
Cam button only needed if putting a retro roller cam in non roller block where it does not have provision for the retainer plate
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
