84 Valve Covers......
Old Jun 9, 2012 | 07:56 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I got a 84 z28 carbed, and I assume that my valve covers are leaking because I a getting a lot of smoke and it seems like oil is dripping out of them and touching the exhaust manifold and causing smoke to appear, but anyways wanted to know if anyone knew how to remove the covers without damaging all of the hoses on the passengers side??thanks!
and I was also wondring fi it would be a bad idea to spray paint the covers flat black?thanks! or would i need a special kind of paint and if so any recommendations?thanks!
Old Jun 9, 2012 | 08:29 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 84 Valve Covers......
Label the hoses, take pics, then undo the hoses. There's no other way.
Old Jun 9, 2012 | 08:37 PM
calgutie's Avatar
Car: 1984 Z28
ye ur rite,,, bu you think ide be alrite if I clean em up and hit them with regular black spary paint or you think i might need some kind of special spray paint?
Old Jun 9, 2012 | 08:54 PM
smokin berlinet's Avatar
Car: 1984 Chevy Camaro Berlinetta
Engine: 305sbc...soon...406 SBC
high temp spray paint is cheap....
Old Jun 9, 2012 | 09:10 PM
Kyxxer's Avatar
Car: 1984 Z28
Engine: 355
Axle/Gears: 3.73 LS
i changed my calve covers my self in my garage, wasn't to hard like he said take pictures and label the lines to make assembly EASY as pie lol
Old Jun 9, 2012 | 10:27 PM
mickeypatches's Avatar
Car: 1984 camaro z28
Engine: 305 v8 h.o.
I just finished my valve covers about 2 hours ago. I painted them Chevy red-orange, first you want to get all the rust off or otherwise the paint will not lay on properly. I did this with some dawn soap and water and then some kerosene after that and scrubbing with some scotchbrite. It looks good and cleans stuff up. Be sure to label EVERYTHING. I forgot to and I was searching for about an hour for where things go. If you need the proper way to do it look in a haynes manual
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
