Engine burning oil.? Additive for temporary fix.
Old Jun 9, 2012 | 09:32 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
This seems like a popular topic, so I apologize if this is some where in this forum a hundred times. But I am trying to get my car to pass emissions, it fails only because there is blue smoke at start up. The blue smoke blows out about 1 out of every 8 start ups and its just my luck that it does it when I take it in for emissions. I took it to two different shops and they said that I need an engine rebuild because my car blows out smoke when held at high RPMs and is constantly burning smoke. Seeing as I do not have the money for another engine at the moment, im looking for a temp fix, just so I can pass emissions and have my car. I have heard remedies such as using thicker oil, using the lucas engine seal product, even something called Alemite CD 2 that did the trick. Does anyone have any tips or anything they know that will help in this situation.? I am planning on getting a new engine, but no time soon. And also, what damage can be caused from driving a vehicle that burns oil.? I hear ppl saying it does no damage to the engine, just that it burns oil, as their car has been doing it for years. And I hear other ppl saying you will destroy your engine if you drive it like that. I have a 92 Chevy Cam, 179xxx miles on it 5.0 TBI Engine.
Old Jun 9, 2012 | 09:53 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: Engine burning oil.? Additive for temporary fix.
Most likely just bad valve seals. Could also be piston rings.
Dont use any of those additives like stop leak, and id be nervous abt adding any kind of additives. I would definetly put thicker oil in. They sell smokeless oil too, so although it doesnt "fix" the problem, you cant see the smoke. I would probably try this first, just for the inspection purpose.
It depends on how bad it burns oil, but usually it doesnt hurt anything. Just make sure to keep an eye on your oil level
Old Jun 9, 2012 | 10:00 PM
mygta87's Avatar
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
dont use any additives they always say theres no technician/mechanic in a bottle that will solve your problem it might just make it worse.
it use to happen to me on my 87 GTA i did my head gaskets took my heads to get checked change valve seals... and it fixed my problem so it might be the valve seals like BLACK88Z says as well. can also be ur piston rings...
Old Jun 9, 2012 | 11:03 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
here's what I used recently http://www.oreillyauto.com/site/c/de...2358&ppt=C1941
I still have a little smoke at start up but it's no where near as bad as it use to be. My dad and I love these Lucas products. They have a good oil stabilizer too
Old Jun 10, 2012 | 07:27 AM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I always add STP blue bottle to my engines with out flinching. I have never had any problems.
Old Jun 10, 2012 | 08:13 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
blue smoke on start up is most likely bad valve seals . just change them out there cheap an you should be able to do it in a weekend .
evilstuie
Jan 9, 2020 08:29 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
