PCV/Breather Question - Oil Leak?
Old Jun 11, 2012 | 01:01 AM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Heres the deal. I have a fresh 350 vortec that I just put in my 92 RS. Everything runs great except I have a small oil leak out of the front of the oil pan gasket only after the car is warmed up and running. I believe I am having a crankcase ventilation issue and excessive pressure is building up and pushing oil out of my oil pan gasket?
I am running two breathers, one on each valve cover. Should I try a PCV system? The breathers are old and seem to be filled with oil.
Suggestions?
Old Jun 13, 2012 | 11:42 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Re: PCV/Breather Question - Oil Leak?
Update*
Put a PCV system back on the car and the oil leak as subsided. I guess I was right, crankcase gas pressures were building, pushing oil out of the oil pan gasket.
Old Jun 13, 2012 | 01:24 PM
sorch60's Avatar
That's interesting. I'm getting a similar leak and i know my line from the carb to the PCV is not making a good seal, I'll have to replace it and see if I get any improvement.
Old Jun 13, 2012 | 01:48 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Definitely worth a shot. That short piece of 3/8" hose is cheap. Plus that means you have a vacuum leak.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
drathaar907
Aug 6, 2015 04:20 PM
