Video of Motor sound> any ideas??? Thx
Old Jun 11, 2012 | 08:44 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
http://s828.photobucket.com/albums/z...t=P1090814.mp4
The noise was not bad at first, but really bad now. Not sure if it is the water pump or steering pump or something else all together. Any ideas?
Thank you for your help in advance
Old Jun 11, 2012 | 09:54 PM
Engine: MPFI
Re: Video of Motor sound> any ideas??? Thx
bump, really no one?
Old Jun 11, 2012 | 11:06 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Get a long breaker bar or piece of a wood broom stick, &
CAREFULY put 1 end on a suspect component, your ear to the other end.
Keep it away from moving parts like pullies, belts, fans...
Kinda sounds like a bearing going // gone bad-- alt, pwr steering pump, water pump, tensioner. iPhone sound quality leaves alot to be desired! Lol!!
Sorry not much help, that's all I can come up with.
Old Jun 11, 2012 | 11:30 PM
Engine: MPFI
Thank you, a friend is coming to look at it tomorrow. I took the video with a camera.
Its a pretty ugly noise. Anyone else want to take a guess or maybe you have had same problem and know!!!
Old Jun 12, 2012 | 01:21 PM
RoRoYoBoat123's Avatar
it sounds like one of the piston's (im not extremely technical), the rods that connect to the piston, it sounds like its loose and hitting the inside wall around the piston (like i said, im not extremely technical), mine used to make a simialar noise and changing oil fixed mine, but yours is way more serious, and if it got worse with time, it would make sense that more running would make the rod more loose. Good luck
Old Jun 12, 2012 | 01:54 PM
Car: '87 Camaro
WOW!!!
Big difference from iphone to desk top sound!!
Agree with RoRoYboat-- sounds alot like it's about to throw a rod
OR
valve train problems.
Check the oil dipstick for metalic shimmer & girt.
Do you recall if you had oil pressure, and how much?
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
stalkier
Aug 13, 2015 12:59 PM
slade5612
Aug 11, 2015 07:19 PM
THX181
Aug 6, 2015 10:21 AM
