87 camaro leaks fuel from starter?
I'm posting this for my cousin who just recently bought a 87 camaro, he gave it a full tune up got it started and all. then instead of changing a bad solenoid he replaced the whole starter since it was old and had rusted and was even corroding, after changing it he tried to start it and it turned over but didn't start. when he got out of the car he smell gas and check under the car. and there was gas coming from the area of the starter. is it a problem with the starter or maybe something else?
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: 87 camaro leaks fuel from starter?
Don't try to start it.
Check all fuel lines & connections. Replace as needed.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
db057
Aug 11, 2015 10:11 PM
