Installing Mechanical Temp Guage....
Old Jun 17, 2012 | 10:27 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So my 84 z28 (carbed engine) temp gaug eis not working but i was thinking of just buying a mechanical temp gaug eand putting it into the air manifold but I am in the process of replacing the thermostat and saw this opening but IDK what that sensor is/does, herers a pik of it. its the one with the lil blue cap on it...
Size:  75.8 KB">Name:  IMG_20120617_082254.jpg
File Type: jpg
Old Jun 17, 2012 | 11:22 AM
Re: Installing Mechanical Temp Guage....
That controls the fuel vapor canister purge.
Can't do away with it. Gotta have it for inspection.
Just repair your stock temp gauge... start by looking for the sensor in the driver's side head between the #1 & #3 spark plugs, make sure the wire is hooked up.
Old Jun 17, 2012 | 12:08 PM
calgutie's Avatar
Car: 1984 Z28
you wouldn't happen to have a pik of it would u?and you think I can get a better view of it from the top of the engine or the bottom, kus I am having difficulties locating it, thanks.
Old Jun 17, 2012 | 02:00 PM
No, sorry, no pic...
Pretty easy to get to from above. In between the #1 & #3 spark plugs (I think we all know where those are?). Looks kinda like a sensor, stuck into the head right there. Should be able to just stand there and look down at it and see it.
Old Jun 17, 2012 | 02:41 PM
calgutie's Avatar
Car: 1984 Z28
hmmm....ok then ima chek it out...hopefully its just loose.
Vintageracer
Jan 10, 2020 05:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
gta90
Sep 15, 2015 04:00 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
