Engine slightly bucking under light load
Old Jun 17, 2012 | 12:53 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I've noticed that while cruising at a constant speed the engine has a very slight hesitation or buck to it. If I press the throttle down just the slightest amount, it goes away. I did notice that after using all the Mobil gas in the tank and filling with Citgo gas it got much better.
Motor is a 350 sbc, 650 mighty demon carb, Canfield heads, 20 degrees initial timing, 35 total, 10 degrees vacuum advance. Primary jets are 72's. To cruise at 50 at 1500 rpm I'm barely on the throttle. Its little enough that how the idle is tuned affects how it drives.
Old Jun 17, 2012 | 01:35 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
Re: Engine slightly bucking under light load
you probably have too much timing advance. Mine did the same thing so i retarded the timing a few degrees and it went away
Old Jun 17, 2012 | 04:00 PM
built91Z28's Avatar
Thanks. I'll try taking 5 degrees of vacuum advance out of it.
Old Jun 17, 2012 | 04:04 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
How old are your plug wires? Make sure they are all good and not burnd or arcing to ground.
Old Jun 17, 2012 | 04:05 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
my car w/ a 6-speed does it too, your most likely just lugging the motor
theshackle
Sep 17, 2020 08:26 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
