Vacuum advance distributor on a TPI motor?
Old Jun 17, 2012 | 03:03 PM
he_mech_usmc's Avatar
Car: 1985 Z-28
Transmission: 87 700R4 repl. for 85 700Rjunk
I am wondering if it is possible to put a vacuum advance distributor in my TPI...none of the parts stores have a distributor in stock and it would take a few days to get one in...rebuilt, none new. However they do have the MSD and Accel HEI distributors in stock with vacuum advance. Would it be as simple as dropping it in and running a vacuum line from the intake or is there more to it?
TIA,
Josh
Old Jun 17, 2012 | 03:59 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Vacuum advance distributor on a TPI motor?
Won't work. The distributor acts as a cam position sensor and tells the injectors when to fire. With an older style HEI distributor, your injectors won't fire and if they are like the 90's silverado's, your fuel pump won't run.
Old Jun 17, 2012 | 04:41 PM
Car: 1985 Z-28
thanks, just wanted to check...this car is currently the bane of my existence...my '79 Porsche 928 is so much easier to work on...the distributor that I have in there now is a stock dizzy, but it's been rebuilt....thinking that it's all in the computer again...
Thanks,
Josh
drewdock87
South Central
Aug 18, 2015 09:02 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
