Factory Tach is way off.
I have a 1992 RS. The factory tach shows 1800rpm just idling and around 4000rpm at 60mph, and it is in OD.
The original 305 was replaced with a 350 GM crate motor, or at least that is what I was told when I purchased the car. Not sure if something was connected wrong or it is a little more complicatd than that. Any help would be great. Thanks
Re: Factory Tach is way off.
Actually, it's EVEN LESS COMPLICATED that that... not complicated at all.
The tach is bad. They just about ALL are. They all fail that exact way; by reading STUPID high.
There's a post on here somewhere about it... like most such "defects by design"... do a search for something like "tach repair resistor" and see what turns up.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Yah even then the tach is still going to be painfully inacurate. If you have an auto it doesn't really need an aftermarket tachometer. Unless you get a shift kit plus an aftermarket shifter and plan on shifting manually during racing.
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
gta892000
Sep 16, 2015 12:37 AM
