HELP !!! Where is 6 degrees BTC on a L69?
Old Jun 27, 2012 | 03:14 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Trying to set the timing on my L69. I noticed with the timing light that there are 4 to 5 (hard to tell, kind of dirty down there in the crankcase) triangular blade shapes. Which one do I shoot for? I cannot see any numbers associated with the triangles. The white painted line on the groove is clearly visible.
I already heard about the finger int he spark plug hole method, but I'd rather do it with the timing light...Spent some $$$ on the light, you know...like to think its useful.
Chuck
Old Jun 27, 2012 | 03:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: HELP !!! Where is 6 degrees BTC on a L69?
Old Jun 27, 2012 | 04:55 PM
Chuck84TA's Avatar
Thanks!
Chuck
Old Jun 27, 2012 | 05:25 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
That's a great picture. Interesting that it shows 6 degrees at the 10 degree mark. Of course, 10 degrees is generally a better setting for stock TPI than the OE 6 degrees.
Old Jun 27, 2012 | 07:23 PM
BrownBullet83Z's Avatar
Car: '83 Camaro Z28
Engine: "Just a little something"
Axle/Gears: 3:73
Thanks for saying that ASE! I was thinking the same thing and was going to post but you beat me to it. It is odd!
RedLeader289
May 28, 2019 01:47 PM
PurelyPMD
May 5, 2016 04:57 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ironbmt
Sep 27, 2015 06:00 AM
