Speedo Gear Identifcation
Car: 92RS
Engine: LQ4
Transmission: 4L80E
I've got a 1992 RS with a 700R4 that im looking to recalibrate speedo gears in. My question is 1992 the first year for the 700R4 to use a speed sensor that works on pulses from the output shaft vs. a traditional gear setup? Trying to sort this out so I order the right parts
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Speedo Gear Identifcation
The drive and driven gears are getting hard too find for the 700r4 . dakota digital sgi-5 is a alternative.
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Engine: Lb9
Transmission: M20
tbi 2k vss to a vss buffer , tpi 2k vss maf to a buffer tpi sd 4k to the ecm
Car: 1987 iroc
Sorry, thought you wanted to recalibrate your gears. 4 pulse, probably.This sensor puts out 4 pulses per turn. A four pulse sine-wave (A.C. current or alternating current) signal is required by the 1990-1993 TPI, 1992-1993 LT1 engines and 1990-1993 Camaro 3.1 / 3.4 V6 engines
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Engine: Lb9
Transmission: M20
Car: 92RS
Engine: LQ4
Transmission: 4L80E
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
