What oil filter? Simple but a royal pain...
Old Jun 28, 2012 | 01:20 PM
dezertvet250's Avatar
I bought an engine with the casting numbers 14093638 (350 5.7L vortec). I bought it and put it in my boat. I seem to be having a oil filter issue and am not sure if I have the right one. The place where I bought the engine they could only give me broad specs about the motor (years 96 to 2000, 350 5.7L vortec) and of course the auto parts store wants complete details. I've looked over many fourms with no luck. So I'm turning to you all for help.
What is the right Oil filter for this motor/block? I'm currently using a fram ph5 but I blew the ring/seal out twice. The engine shop thinks it could be a AC1218 but even he wasn't sure,(dont think I will be doing business there again).
Old Jun 28, 2012 | 01:25 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: What oil filter? Simple but a royal pain...
Shouldn't it be a Fram PH3506 ?
Old Jun 28, 2012 | 01:37 PM
thanks for replying but I don't know that's why I'm asking.
Old Jun 28, 2012 | 01:53 PM
Richboll's Avatar
Engine: 305 TBI
Try a AC Delco PF 52 or Fram 3980 These are listed for the 5.7 Vortec engine. I'd also take a look at the oil filter seat to make sure that the surface of the adaptor isn't cracked or has some other defect.
Maybe someone out there has another answer.
Old Jun 28, 2012 | 05:01 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Check to see if the gasket from the other filter is stuck on the engine. Sometimes this happens, and trouble like this can occur.
Old Jun 28, 2012 | 05:19 PM
Should be the 1218.
Don't think it's the 52; seeme like that's the one for the newer motors (LSx type). Too small OD, wrong thread.
As Steve said, make sure there's not a leftover O-ring from a prior oil change left stuck up in there.
DO NOT use a Fram. ANYTHING BUT a Fram.
Old Jun 28, 2012 | 06:38 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If you were using the Fram filter PH5 the Bosch equivalent # 3510 and that is the exact filter I use.Its listed as a 350 truck filter and is twice as tall as the one that is listed for the car .IMO it a great filter that competes with the so called top end filters.
Here's a link to the Fram cross reference page.= http://www.framcatalog.com/Competito...n=3510&em=True
Here's a link to the Bouch filters design.= http://www.boschautoparts.com/filter...ilfilters.aspx
and you can buy it for around $6.00.
Found this at Wikipedia = In mid 1996 the L05 was equipped with Vortec heads used in the 1996 G30.
There is no reason that filter will not work.
Old Jun 28, 2012 | 09:18 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I used to be a proponent of using the tall filter for the benefits of more oil capacity, better cooling, and maybe even better filtering. But although the possibility is slim, if your oil filter is the lowest thing to the ground, it would be exposed to damage, and you could lose your oil. Oil filters are made of pretty thin tin. Check by sticking your head under the front of the car and take a look at that long filter. Imagine what you would do if you were a road hazard and then make your decision. I switched back to the filter the catalog calls for, which is usually the short one.
Old Jun 28, 2012 | 09:44 PM
Richboll's Avatar
Engine: 305 TBI
Ground clearance shouldn't be a problem. I think its in his boat.
I use Fram filters all the time and have never had a problem with them.
I only said the AC PF52 because that's what was listed for that engine. If that is wrong, thank you for correcting it.
The possibility of a second gasket stuck there is a good suggestion.
Old Jun 28, 2012 | 10:56 PM
Engine: TBI,5.0
Ive looked at it many times while under the car and never have I thought it was in any danger ,thats even with a temperature controlled sandwich adapter . I need to get under the car tomorrow so Ill take a closer look.
Old Jun 29, 2012 | 02:57 PM
Engine: TBI,5.0
I'm not trying to steel this thread but would like to add my findings on the tall oil filter I have been using.
With the 1in. thick sandwich adapter for my fluids the filter is flush with the lowest point of my undercarriage.That means Ill be using the shorter filter that is listed for my car.You don't even know how much a small thing like going to a smaller filter bothers me.. I run the extended performance synthetic Mobil 1,so saying that both the tall and short filter are being used with the same exact conditions how much of a difference does this make?
I only drive the car about 2000 miles "mostly stop light to stop light" a year and change the oil evey other year. Will the smaller filter handle that?
Old Jun 29, 2012 | 03:09 PM
The size of the filter will only determine how much oil it will retain. If it is a 5 micron filter it will filter out particles as small as 5 microns regardless of the size of the filter.
Old Jun 29, 2012 | 03:18 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Loom at the oil filter for the new vettes, tiny! Gm says it's better to have oil in the engine then in a filter.
Old Jun 29, 2012 | 03:36 PM
If GM says that, they are full of it. If the filter holds more oil, more will need to be added to the crankcase to make up for it.
Old Jun 29, 2012 | 04:46 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I run the PF1218CL on my cars.
Old Jun 29, 2012 | 04:56 PM
Engine: TBI,5.0
OK, I went to Orileys Auto Parts and looked at the shorter filters for my car.They had a large inventory containing the top rated brands.I decided that if I have to use the smaller filter I would use either K&N or the new Mobil 1 extended performance .Both cost about the same at $12.50 ea.I look at the K&N first and was disappointed to see it was almost as tall with that nut they put on the bottom.I went and looked at the Mobil 1 extended performance ,and it was the regular size about half as tall as the one Im replacing. If its really any thing like the box says, its is more than I expected to find. Here's the link to the Mobil 1 web site showing the filter.
http://www.mobiloil.com/usa-english/...l_filters.aspx
Here's a link comparing filters = http://minimopar.knizefamily.net/oil...reference.html
Old Jun 30, 2012 | 04:33 PM
Thank you all for the support. I am beginning to think I have a totally different problem. I believe I have an entirely different motor, at least years, than the specs the engine place gave me. I will start a new thread for this.
I believe the oil pressure is to high.
And it is in a boat so I have plenty of clearance.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
