92 camaro problem
Old Jul 1, 2012 | 10:31 AM
92_RS's Avatar
92 camaro problem
Hi everyone I'm new to this site, well first of all I just got a 92 camaro Rs everything works fine ac works perfect...so when the car is on n the ac is on it runs good as soon as I put it into gear it dies, the only thing that can fix the problem is raising the accelerator but I kinda don't wanna do that so I have no idea what the problem can b...any idea on what it can b or how I can fix it? My neighbor said it could b the throttle position sensor
Old Jul 2, 2012 | 11:55 AM
cw3adkins's Avatar
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
Re: 92 camaro problem
Does it do this if the car is put into gear and the AC is off?
Old Jul 2, 2012 | 11:49 PM
92_RS's Avatar
No just when the ac is on but with the ac off it will run for like a good 10-15 mins n then it dies n then I have to put it in park n then turn on the car again
Old Jul 3, 2012 | 01:32 AM
TwinTurboROC's Avatar
Is it a sudden shutoff? or a sputtering shutoff?
You may need to clean and reset the IAC valve.
Old Jul 3, 2012 | 01:34 AM
BTW your 10 to 15 min shutoff may be another issue.
Can you rev the car a little and turn the ac on? Does it die then?
Old Jul 3, 2012 | 02:08 AM
92_RS's Avatar
It only dies after 10mins if I'm stopped for a while at a light or something N it just dies but I highered the accelerator n no problems but I don't wanna drive like that n it's a automatic just putting that out there
Old Jul 3, 2012 | 02:10 AM
92_RS's Avatar
N some times the check engine soon comes out only sometimes it goes n comes...they checked it with the diagnostics n nothing came out 0 errors n it wasn't at some autozone lol so idk what I can do to fix the problem
Old Jul 3, 2012 | 02:25 AM
The check engine light could be a EGR Problem. Does it come on when your driving?
You should first try and clean and reset your IAC valve.
Your car may have more than one issues.
Do that first and get back to us. If you search there are a few posts on how to remove and clean the IAC valve. Also there are some posts on how to reset the ECM sided of the iac.
TPS sensor would have nothing to do with Idle problems.
Also, im not knocking you, but can you use a some better english. The N's were confusing me to thinking you were referring to Neutral AKA "N"
Old Jul 3, 2012 | 02:30 AM
92_RS's Avatar
I'll check on that tomorrow and sorry I'm using my iPhone and I'm used to txt format lol
Old Jul 3, 2012 | 02:32 AM
92_RS's Avatar
And yea it comes out when I'm driving but only some times not all the time
Old Jul 3, 2012 | 02:42 AM
That engine light comming on and going off 9 times out of 10 is the EGR system, Alot of us have this problem and just ignore it as 10 times out of 10 it is a ghost code. Well ghost enough to ignore.
Old Jul 3, 2012 | 02:59 AM
92_RS's Avatar
I just wanted to ask Driving with the accelerator a lil higher then normal bad? Cause so far with the accelerator moved a little higher...deleted the problem ac works it doesn't die or anything...and another question is on these cars is it normal to jump when switching in gear mostly drive and so with the EGR should I just clean it or get a new one? Sorry I'm new to the camaro scene and all these problems
Old Jul 4, 2012 | 12:23 AM
OK definately sound like a IAC problem. DO a search on "IAC reset" and also "IAC cleaning" (you could also use idle air control instead of IAC).
Clean and reset it. Then disconn the negative batt terminal for about 1 min. It will reset your pcm. Then reconnect and start it. It may stall out 1 or 2 times. Press down on the gas pedel a little to keep it alive if its doing that until the computer learns the idle. Bout 30 seconds to a minuet or 2.
Old Jul 4, 2012 | 12:29 AM
Check your trans fluid level. Start the car let it warm up. (or rev it to about 1000 rpms to keep it alive) then with the car runnning pull the trans dipstick out, check the level at the hot mark. Should be somewhere in the cross hash area. (little x's)
You probably have a bad motor mount if it jumps or clunks when you shift into gear. Youll hear the thud in the trans tunnel and on the floor.
IF NOT you may have a bad accumulator spring inside the trans. Not newbie stuff to be dealing with.
92camaroJoe
Jul 29, 2023 07:57 PM
TheJoeY88
Dec 31, 2016 07:30 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
