Battery relocation - where to run thru firewall
Old Jul 2, 2012 | 02:35 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I'm move the battery to the boot on the right hand side using a BMR battery relocation kit.
I've run the positive cable thru the car interior under the carpet next to the right hand side sill panel.
I like the idea of having the hole a bit higher to keep is clear of the ground and exhaust, but a higher location might mean a sharper bend on the cable.
Any suggestions on the best place to drill a hole in the fire wall to get the battery cable to the starter motor?
Old Jul 2, 2012 | 11:13 AM
cw3adkins's Avatar
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
Re: Battery relocation - where to run thru firewall
What gauge wire are you running?
Old Jul 2, 2012 | 01:48 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
You can get through bulkhead fittings that insulate the current from the firewall and have a nice threaded connector on each side. I think Summit has them for an idea of what they are like.
Old Jul 2, 2012 | 06:35 PM
peterc005's Avatar
Transmission: T700
I think it's 0 gauge. It's specialist copper battery wire I bought from a speed shop and is twice as thick as the original battery cable wire.
I've gone to a lot of trouble with the connectors and earth points to get plenty of juice for the starter.
Old Jul 2, 2012 | 07:10 PM
peterc005's Avatar
Transmission: T700
I used the same thickness with the cable in the boot used for an earth.
As well as a terminal for the earth bolted into the body, I ran the metal self tapping screws used to support the BMR Battery box thru the black earth cable, giving it a couple of different earth points, some into the body panels and some into the sub frame.
Up front I'm still not sure what to do with the alternator wire. Either I can replace the cable from the fusable link with a new length run to the starter, of I can lead the old cable and starter cable in place and do it that way. Running a new lenth of cable for the alternator is more work but would look neater.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Bradsaundry
Aug 12, 2015 12:34 AM
