Shift Cable
Old Jul 2, 2012 | 08:19 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Shift Cable
I kinked the shift cable on the GTA and now it will not go into park. I tried a cheap aftermarket one and the damn thing kinked down at the transmission end. Probably my fault on the installation. Does anyone have a shift cable for the stock shifter and 700R4 transmission I can buy?
Old Jul 2, 2012 | 09:16 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Shift Cable
Went thru trying to source a new shift cable last year. Apparently GM discontinued, and the aftermarket ones are all rubbish. At least over there you've got the junkyards.
I went with a Dorman; best of a bad bunch as far as research indicated. Turned up broken so I had to fix the new one anyway
Old Jul 2, 2012 | 09:24 PM
akanitro's Avatar
Re: Shift Cable
How did you fix it?
Old Jul 4, 2012 | 10:23 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Shift Cable
With some redneckery:
https://www.thirdgen.org/forums/tran...t-shifter.html
My new one was broken up at the shifter end though, different to yours. At least the 'fix' has lasted 6 months now.
58mark
Sep 21, 2015 07:21 PM
HikoriYami
Sep 21, 2015 07:11 PM
camaronils
Sep 20, 2015 02:57 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
