any good aftermarket shifter cables
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Hey guys, I was wondering if anyone has found a good shifter cables yet? I broke mine first thing this morning and came home and started doing some research. I found that GM discontinued shifter cables and all the aftermarket ones are junk. The only part that broke on mine was one of the plastic clips. is this whats wrong with all the aftermarket ones? I just finished setting mine up with some zip ties so I could get it back into park but I'd like to find a more permanent fix. Any recommendations?
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: any good aftermarket shifter cables
Apparently there aren't any. I researched this a few months back to replace mine, the consensus here and elsewhere was that a junkyard is the best bet.
That option was not open to me over here, so the Dorman 04620 seemed to be the best of a bad bunch. Ordered one from Summit, and it arrived pre-broken in the box , in a similar fashion to the one in this thread:
https://www.thirdgen.org/forums/afte...er-cables.html
Having no practical recourse over here for returning a $30 part, I managed to fix it with an aluminium sleeve and a hose clamp. After that it installed and worked great for 2 months now, time will tell how long it lasts...
Car: 88 iroc camaro
Axle/Gears: stock
Thanks, with that said it looks like it's time to make my own fix! My double zip-tie trick seems to work well for now. The hose clamp idea was the first thing that crossed my mind too. now I'm thinking of making a piece to slide over the front rubber part on the cable and the back side of the metal bracket to pinch the two parts together. I want to try to eliminate the need for the flimsy plastic clips all together.
Car: 1991 Z28
Engine: LB9
Axle/Gears: Stock
Local pick and pull for $5 off a 1990 firebird. Works great if there is a local salvage yard give it a shot. All aftermarket is junk when it comes to these cables.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I decided to finally replace my factory one which was broken at the transmission bracket when I bough the car nearly 10 yrs ago. Had it tied up with baling wire, tie wraps, and a small wooden wedge.
I gather the aftermarket ones usually break up the top at the shifter mount, whereas my factory one was much thicker at that point and intact.
Happened to take some pix of the fix, which is working fine for now at least.
NBrehm
08-25-2015 11:49 PM
db057
08-11-2015 10:11 PM
