What Should I Set the Timing on my 305 TBI
Old Jul 12, 2012 | 09:01 AM
BigLou907's Avatar
Car: Camaro RS
Transmission: Automatic
Axle/Gears: Not Posi :(
Hello there,
I own a 91 Camaro RS with a 305 TBI. I'm about to replace my distributor. I know that tweaking the timing on your engine can increase or decrease the performance of your car. What should I set the timing on my 305 to get the best performance out of it?
Any input would help.
Thanks,
Lou
Old Jul 12, 2012 | 09:08 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: What Should I Set the Timing on my 305 TBI
It's different from car to car usually. Advancing your timing a little bit can improve performance, but might affect how long your parts last.
Old Jul 12, 2012 | 09:32 AM
BigLou907's Avatar
Car: Camaro RS
How many degrees should I advance the timing?
Old Jul 12, 2012 | 09:33 AM
Dakota W.'s Avatar
Not much, just until the car starts to run a little bit faster, it's hard to explain. It won't run right if you go too far though.
Old Jul 12, 2012 | 10:55 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
It has to be set to what the computer is expecting the base timing to be. In the case of TBI, I believe that is zero degrees (with EST wire unplugged of course). Then with the wire plugged back in, the computer can do it's thing and add the correct timing for the situation.
Do some searching, some guys set it a few degrees higher and report possible differences.
pimp2303
Jul 27, 2017 02:03 PM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
MENINBLK
Aug 5, 2015 11:58 PM
