1991 z28 stalling at stop
Old Jul 18, 2012 | 04:22 PM
djjd's Avatar
well i have a 1991 z28 with the 350 in it/lately it has been stalling when coming to a stop/i have replaced the distributor/ fuel pump/plugs /wires/numinous sensors/lol and just about everything else/am at a stop/ i read in here that the speed sensor will cause this problem it was awhile ago and i cant find the thread/is this true /the speed sensor is shot so will probably replace any ways/but i would appreciate any other ideas that you alll have Thanks to anyone replying any ideas would be most helpful DjjD
Old Jul 19, 2012 | 06:24 AM
maxjivi05's Avatar
I have this same problem can someone please help us? I've replaced Button, Cap, Pick-up and Ignition Coil, cleaned out TPS Sensor. I'm confused when I get paid I'll change plugs and wires but would they go bad when warmed up but not when cool?
Old Jul 20, 2012 | 01:36 PM
cw3adkins's Avatar
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
Re: 1991 z28 stalling at stop
Unless the wires are arcing or damaged, I wouldn't think that would be the problem. Have you guys checked your vacuum lines for cracks and leaks?
Old Jul 20, 2012 | 02:52 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
I had a similar issues and it turned out be the injectors.
Old Jul 20, 2012 | 04:21 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
That's a nice looking Camaro!
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
sounds like a vacuum leak. go through all your lines. is throwing an SES light?
Old Jul 22, 2012 | 10:20 AM
djjd's Avatar
no m8 funny not showing any ses light /but funny thing is when i replaced the speed senser the problem has mostly gone away /it still happens on occasion but very seldom/going to have to go with a vacuum leak seems the most probable/then injectors>want to thank everyone for the input will get back to you all with results ahh the wonders of working in a f body car lol /ahh have another ? had the exhast system replaced with what was supposed to be a oem system but when i got under the beast they had put in a exhaust for the 305 instead of the proper one /would this cause backpressure issues causing it to stall out just wondering oh well back to the shop /enjoy your day everyone thanks again djjd
jklein337
Sep 19, 2018 06:23 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
deracer
Apr 11, 2016 12:04 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Bryan F
Aug 18, 2015 02:28 PM
