oil leak! help needed
Old Jul 18, 2012 | 08:15 PM
mike22115's Avatar
Car: 1990 firebird formula
Engine: 355 HSR comp xfi 268 vortec heads
Axle/Gears: 3.27 BW 9bolt
so ive noticed a oil leak. i look under the car and see that my oil filter is wet with oil? so i check if its tight, and it is. so i then pull the filter off to check the gasket/o-ring on the filter is cracked. its fine, but just to be sure i changed the filter anyways and its still leaking! it appears to be from somewhere above the oil filter. but idk anyhelp is much needed!
Old Jul 18, 2012 | 08:36 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: oil leak! help needed
If your car has a oil cooler or even if it doesnt, check the oil filter adapter that bolts to the block for being cracked or broken.
Old Jul 18, 2012 | 08:47 PM
Oil pressure sending unit, valve covers
IROCZ1989
Jan 24, 2016 03:55 PM
Navy8125
Aug 21, 2015 09:32 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
drathaar907
Aug 6, 2015 04:20 PM
