difference in spring retainers?
Old Jul 22, 2012 | 09:52 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
can someone tell me the difference in spring retainers? im looking at getting a set of ls6 yellow valve springs and it says that if im going to run these springs in my vortecs i need to get comp cams retainers. but i fail to see the difference in the retainers because i still have my stock valve spring retainers.
Old Jul 22, 2012 | 10:25 PM
GreggymacZ28's Avatar
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
Re: difference in spring retainers?
It's all about the R-G clearance on vortec's. If the retainer is too large, you wont get enough clearance and then you will break some springs. I know that my alex's retainers added alot of clearance over my stock retainers for my vortec heads, i forget the exact number now though.
Running a good seal will also help with your clearance, just make sure you measure from the bottom of the retainer to the top of the valve stem seal with a digital caliper to insure that you have enough clearance and wont be breaking anything. That's how i got my .540 lift cam in my vortecs.
customblackbird
Aug 15, 2021 10:16 PM
Cameeeero
Sep 18, 2015 04:00 PM
gixxer92
Sep 1, 2015 04:32 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
