92 Camaro RS 3.1 MPI Losing my Mind Stalling
Old Jul 22, 2012 | 10:04 PM
92camaroJoe's Avatar
Car: 92 Camaro RS
Engine: V-8 305 TBI
Hello Everyone
I neeed input on this from anyone
here's the details
engine stalls but not instantly at almost every stop, as engine warms it does seem to get worse.
when I stop at a light or sign it may run for a short period but most times before i pull off it will stall, sometimes it kind of surges in RPM and then stalls. BUT it always and I mean ALWAYS starts right back up, no problem at all, ever.
I have replaced.
Plugs
Spark Plug wires
cap & rotor
ignition coil
ignition Module
EGR Valve
MAP sensor
IAC valve
Fuel Filter
checked Vacuum and compression and timing
of course the SES light never comes on to indicate an issue except only when the engine has actually shut down and that's just normal prestart condition
any suggestions?
Joe
Old Jul 22, 2012 | 10:26 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Re: 92 Camaro RS 3.1 MPI Losing my Mind Stalling
Timing out of wack, iac motor not working
Old Jul 22, 2012 | 11:18 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Check your fuel pressure first. See what it is at idle, what it does under throttle, WOT, and how long it stays after shut off. Ohm all inj, cold and hot. Should be 17+ and within .5 of each other.
Does it have a rough idle? What rpms does it idle at?
What engine?
Just for the hell of it, try running the codes. See if it gives you anything. Maybe when it stalls and gives you the ses light and you think its normal, its really giving you a code(s).
Old Jul 22, 2012 | 11:22 PM
Car: 92 Camaro RS
Engine: V-8 305 TBI
TO: iggy1991
as i said
IAC motor replaced and checks
timing dead on
Old Jul 22, 2012 | 11:31 PM
Car: 92 Camaro RS
Engine: V-8 305 TBI
What engine?
TO: Black88Z
Q:Check your fuel pressure first. See what it is at idle, what it does under throttle, WOT, and how long it stays after shut off. Ohm all inj, cold and hot. Should be 17+ and within .5 of each other.
A:haven't check pressure as it is kind of inconsistent with problem but i will, the injectors would cause a miss? no miss
Qoes it have a rough idle?
A:not really
Q:What rpms does it idle at?
A:1200
Q:What engine?
A:my subject says 3.1 which is a v-6
Q:Just for the hell of it, try running the codes. See if it gives you anything. Maybe when it stalls and gives you the ses light and you think its normal, its really giving you a code(s).
A: as I said no codes
Old Jul 22, 2012 | 11:45 PM
Black88Z's Avatar
Sorry, I looked right over where it said 3.1!
Injectors can act very strangly when they start failing, causing all kinds of frustrating problems. Ohming them will tell if the electronic-half of them is any good, but the injector could still be in failing operating condition. Its very common for them to get worse as the engine warms up too.
Id still check fuel pressure too because it isnt hard, doesnt take long, and its nice to be able to check that off as OK. My car when I got it was giving me similar problems, turned out my pump and sending unit were shot.
I would check the TPS too.
Old Jul 23, 2012 | 12:30 PM
iggy1991's Avatar
Check fuel pressure. On mine it was doing kinda the same thing. Ended up being the fuel regulator.
Old Jul 23, 2012 | 01:15 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Good information on doing an idle learn and cleaning of the TB:
https://www.thirdgen.org/forums/v6/1...dle-learn.html
If you have recently disconnected the battery and your car has an automatic the idle learn will/should correct the stalling.
RBob.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
92camaroJoe
Aug 13, 2015 06:07 AM
